Ford 1940 (style hot rod)
Post new topic   Reply to topic    FORUMAUTOPLUS Forum Index -> Automobile -> Voitures anciennes
PostPosted: Sun 13 Apr 2008, 06:28 pm    Post subject: Ford 1940 (style hot rod) Reply with quote
Voiçi un Ford de 1940 qui a été passablement modifié , son moteur est maintenant un 302 p.c. de Torino 1970, la puissance serait donc de 225 H.P. environ :
L'intérieur semble avoir besoin d'attention :
La description :
Up for auction is a super solid ALL STEEL 1940 Ford Coupe street rod. This car started its life as a rust free 40 Ford coupe which was then heavily customized to 50-60's style era. The car has been chopped 3 inches, 59 Chevy headlights added, 39 Ford deluxe grill, rolled pans, 50 Pontiac taillights, recessed license plate, custom hand formed all steel running boards, along with many other super clean custom touches. All body work was leaded and finished beautifully. You will not find a better body then this car. Immaculate original floors (See Pics). Mechanically the car has a 302 with a c4 auto tans pulled out of a 1970 Torino with 30k miles. The motors runs like a top and the trans shifts strong and clean. The rear is a 9" Ford out of a Maverick. The front suspension is a dropped axle with disc brakes. All chassis components are brand new top of the line Chassis Engineering. The steering is a flaming rivers vega box and flaming rivers column. The car has four BRAND NEW gennie steel wheels powder coated red with new 46 Ford caps. The car has got a fuel cell and battery located in the trunk. Also, features an aluminum radiator and new 2 1/2 custom exhaust. The interior was started, but will need finishing to your taste. The dash is an all steel original dash which was custom filled. New dolphin gauges.(no speedo installed) All garnish mouldings are chopped and fitted. Seat is the original bench. The cars has been fully insulated in the cab and trunk. Full brand new EZ Wiring harness. Power windows. New Lokar shifter. The only thing not installed in the interior is the headliner, which is included in the auction (brand new in the box). This was built with all high end new components on a rust free all steel car. The car can be enjoyed as-is, or painted and finished to your preference.
L'offre minimale n'est pas atteinte avec $17,300.00.
PostPosted: Sun 13 Apr 2008, 06:35 pm    Post subject: Ford 1940 (style hot rod) Reply with quote
J'adore le noir mat pour une voiture mais dans ce cas ci elle n'est pas formidable...en plus les roues rouges...nope et sans oublier est-ce une couverture ou c'est vraiment le revetement des sieges?
personnelement j'aime mieux celle de ce clip!
PostPosted: Sun 13 Apr 2008, 06:38 pm    Post subject: Ford 1940 (style hot rod) Reply with quote
Ca fait Rock a Billy.
PostPosted: Sun 13 Apr 2008, 06:39 pm    Post subject: Ford 1940 (style hot rod) Reply with quote
Dit pas ce mot la...on va avoir Lucien Francoeur qui va s'inscrire sur le forum
PostPosted: Sun 13 Apr 2008, 07:00 pm    Post subject: Ford 1940 (style hot rod) Reply with quote
Mechant clip de malade pour une fois je prefere cette version a l'original! Okay
Cependant dans la voiture presenter par Mr.Mustang, les phares n'ont pas trop trop l'air original, ca fait different.
PostPosted: Sun 13 Apr 2008, 11:10 pm    Post subject: Ford 1940 (style hot rod) Reply with quote
En effet,ils viennent d'une Chevy '59...et je trouves l'ensemble plus ou moins réussi...
Voilà sans-doute la principale raison sa valeur marchande en difficulté...
PostPosted: Mon 14 Apr 2008, 06:16 am    Post subject: Ford 1940 (style hot rod) Reply with quote
Et oui disons que ca réveille comme toune...quand je parle d'une black betty je parle du char de ce clip!
Post new topic   Reply to topic    FORUMAUTOPLUS Forum Index -> Automobile -> Voitures anciennes All times are GMT - 4 Hours
